2nd Gen Non-Engine/Transmission ball joint options
Engine/Transmission (1998.5 - 2002) The Edge Comp Is On Its Way !!
2nd Gen Non-Engine/Transmission Front axle removal
Ball joints seem to be limited for the newer trucks. They changed the location of the ball joints. They are in the axle tubes. They are a little more of a pain to change. I don't know if anyone offers all 4 joints with grease fittings. I used McQuay-Norris in my 95. They were of high quality. They had grease fittings in them. I'll look for them when my 02 needs them. Hope this helps. Jeff
Thanks Jeff. I think I can drill grease fittings in them. I think one either top or bottom has no room for it permanetly so your need to plug it and remove the grease fitting when done.
