2nd Gen Non-Engine/Transmission Ball joints and wheel bearings-part II
Engine/Transmission (1994 - 1998) Can't drain radiator
Engine/Transmission (1998.5 - 2002) 35/40 hybrid and lag
'02 4x4 auto 120K on the clock. At highway speed (65-70mph) I have a slight, barely noticeable noise coming from the front end when in a turn. When you enter a bend in the road (left or right, makes no difference) you pick up a faint grinding noise. Straighten out and it goes away. Wheel bearings ?
wheel bearings
I have a 2002, 4x2 though. I had the ever increasing noise in the front end as you describe. When I got around to checking it out I found both spindle nuts were lose causing the bearings to fail. I never did determine wether the vibration of a failed bearing was the cause of the loose nuts or vice versa. Replacement was covered under warranty for me. Good thing the bearing, hub and lock nuts are replaced as a unit. Very pricey.
Mr. Mike.
Could be? Are you getting any vibration? What size tires? Does it go away after 70 and doesn't start till 65? @ 60 it's not there?
No vibration, 275/75/16 BFG,s Does not go away at any speed, just less noticeable at lower speed.
