Hello fellas, I have moog ball joints on the passenger side installed not long after I bought the truck, they’re still in there since 2008.
The driver side is still in there when I bought the truck.
I do grease them pretty much every 2,500 kms or 5,000 kms.
I also have been using swepco moly grease from the start so I’m guessing that may have helped as cheap grease seem to push themselves out.
This truck has always had 35” Toyo M/T’s on factory steel rims and run them with 35 psi front and 25 psi rear to get them to wear flat. Loaded with a trailer, the rear is pumped up to 40-65psi depending on how heavy the load is.
I’ve had the truck from 330,000 km up to 550,000 kms that’s on it now.
Same steering parts, ball joints, and only the track bar has been upgraded to 3rd Gen style.
What I’ve noticed and liked, is the low tire pressure cushioning the blows of the roads or pot holed gravel roads.
My truck is smoother over frost heaved paved roads than my car is or my mom’s 2016 Jeep Compass.
I will not buy small tires like 245 or 265 sizes and use high air pressures to keep the tires up.
I’m also a farm helper, so my truck does see off road at times.
I’ve done many farm field drag racing at speeds over 100 kph.
My truck is not a road princess.
My farm tractor is supposed to have 20 psi in the rear tires and 40 psi in the front (2wd) according to tire shops.
But my loader banging up and down over rough spots in the fields is not acceptable so I dropped the front down to 20 psi then raise them when I have a lot of loader work.
The rear shock loads my back even with suspension seat so those have been brought down to 10 psi.
The tractor rides really nice and has been since those new tires were installed in 1999 with no issues.
This saves my loader bushings and steering bushings and my back. This is a 1974 John Deere 2130. Nothing fancy about this tractor
Now both tire shops for my tractor and truck don’t like these low tire pressures but I chose to do that on my own. I do my own maintenance, watching for any issues that may arise.
So far both my truck and tractor are doing well.
The truck is on it’s third set of M/T’s. All using same low pressures.
