Ball Joints, u-joint, and hubs
Quick Wiring Question
05 front end wheell alignment #'s--or settings
Been looking throught the forum but still undecided. What ball joints, u-joint, and hubs should I get and where do I get them from? Other than the snap-on socket what else do I need? Links would be great thanks
After much consideration, I finally went with Dynatrac on everything (all that you mention). Only a little over 6k ago but, so far so good. Also, sticking with one vendor for everything may maximize your chances at 'best cost. ' Lot's of guys on this forum satisfied with the Dynatrac stuff.
I've done quite a few of our trucks front ends now. Carli ball joints or Dynatraxx are the only way to go unless you enjoy doing this job over and over. Moog parts while fine for gasser trucks just can't handle the extra weight of our diesels. I wonder if binding parts is the cause of the death wobble?? I know my truck was un drive able when the moog stuff was binding. Now Moog does make some very good tierod ends. They now offer all the parts to do the 08 upgrade on our trucks. You just have to buy it piecemeal and put the kit together your self. it's a few $$$ but well worth it when you drive the truck after it's installed and your tires will last longer with it as long as it's set up right (read proper "toe in" setting) Right now Dynatraxx has the best price on the ball joint set. Hope this helps
