Balls and Ball mounts
Filtering water for your RV
Any one know anything about horse trailers???
My current setup is an adjustable solid shank 2"x2" ball mount designed for weight distribution bars and rated for 12,000 lbs. The ball is a chrome plated 2 5/16" rated at 14,000 lbs. The drop height is 7" which results in a level trailer. I would like to move to a 1 piece unit to increase the ground clearance but could use some input.
Here are my questions:
- Are there any 7" 12-14,000 lb rated drop ball mounts available?
- I found 2 5/16" gooseneck hardened balls rated at 25,000lbs at a reasonable cost. Could I use this instead of a "standard" hitch ball as long as the shank size and lenghth are correct?
- I did find 8" solid shank drops rated at 14,000 lbs and a raised shaft (1") gooseneck ball that would result in the 7" I am looking for --- any reason why I should not go this route?
Thanks -- BTW the trailer is a Shoreland'r boat trailer that weighs in at 12,000 lbs fully loaded.
I never really figured this out but a gooseneck 2 5/16" ball is bigger than a regular 2 5/16" ball... . unless I am just crazy.
