banjo bolt sizes
ATS Co-pilot settings
I need more RPM's
Just wondering what the size of the straight banjo bolts are on the cp3 pump goin from the pump to the rail (well goin from the pump to the filter bowl then to the rail) i know the size on the pump is smaller than the one of the rail. just trying to get a line made to bypass the filter bowl on a 05-06 cr. thanks
what is the actually size of the banjo part( need to know what sizes to order like -6 or -4 an fitting size or whatever) thanks
wrong order...
fuel tank > lift pump > filter housing > cp3 > rail > injectors
now, from the cp3 there is also a return line on low pressure to tank, and the relief valve on the rail is tee into it along with the fuel return from the back of the head.
why are you looking at putting an "an" fitting on the rail? standard "an" fittings [aluminum or steel speed shop ones] will pop like a balloon at the pressures the rail runs at.
:confused:
i don't have to use a an fitting im just trying to bypass the filter and to do that i have to make one line goin from the cp3 pump to rail. i want to completely remove the filter housing. im putting on a fass system with the filters. and want to know what sizes i need or who might sell them if anyone does? thanks
