Details here: TDR Privileges
Don't want to start a huge post, so please reply via e-mail. All I want to know is why do you need to replace the banjo bolts? What is the reason behind it? Thanks a lot!
Inlet fuel pressure at the VP-44 injection pump is a big issue. Modified banjos reduce the pressure loss between the lift pump and the VP-44 at higher fuel flow rates. Every little bit helps.
