Isn't a fuel press. guage on an G3 a waste of time?
If the engine runs, theres enough, and that doen't mean there is enough pressure to even measure between the lift pump and primary of the fuel pump.
Besides the Low side of the fuel pump is sealed between it and the high pressure side so theres no way to measure that either.
If the engine runs, its primed, and the lift pump has no further task in life. And once running, you should be able to pull the power to the lift pump, its electric, with no effect. The Fuel pump just draws fuel through the lift pump, whether the lift pump is running or not. It will start and run just fine even without the lift pump running if the pump is primed.
In fact, I would expect under heavy throttle, the pressure would be negative, vacuum, as the fuel pump is exceeding the ability of the lift pump.
So I think the fuel pressure guage isn't necessary.
