Banks 24v turbo and ECM thing: anyone try?
LOCK OUT HUBS
Wastegate Elbow
Does this mean there is a Twin Ram for the 24v now. Don't worry HVAC I will get you one if there is.
1996 4x4 3500 4. 10 5spd, Diesel Dynamics stage 2 injectors, olny 1 quarter Banks Power Pack left with 4" exhaust, Cummins exhaust brake, US Gear overdrive, Grover air horns, Mag-Hytec cover, and more.
Oh GAWD!!! My wishes have been aswered if I can obtain a twin blender for my double dozen valve engine #ad
David, the ecm whatever thing you elude to is otherwise known as a Power Max.
The turbo they typically go with is a wastegated 14cm2.
What was the cost for this trick Banks engineering?
Sorry HVAC, but the new Banks intake is a single runner. It seems that you can't put 2 things in the same space (the intake runners and the high pressure fuel lines). But the new intake runner is real nice looking.
99 2500 QC 4X4 5sp 3. 54LSD 285 75X16 AR Atlas / Hadley airhorns / slightly B. O. M. B ed / ISSPRO guages / 33' Hitchhiker triple slide
One correction to the powermax response. As I understand it, the box is made by the same company for both TST and Banks, but the programing inside each box is different. The Banks is much more reserved than the PM, and not adjustable. It also does not have a power switch on it.
Now all this said, I am refering to the original Banks "Ottomind" box, they may have a new product out at this time. I e-mailed both companies a while back, and ask for information on the differences, and got no reply from anybody, so all this is info I have picked up from the "field".
98. 5 3500 24v 5Sp 4X4 SLT w/4" turbo back stainless exhaust, Pyro & Boost Gages, and Boost Module. (Banks Stinger+ Pkg), Rancho RS9000(6), Hadley Air Horns, Warn 12K winch, DD Stage III, K&N, DD Extream Duty Clutch, Firestone Air Lift Bags in the rear & a few other goodies.
