the banks brake is old technology. get a good brake the bd and pac are the best. i like the bd over the pac because of where the compressor mounts.
The PRXB with Banks electronics and hardware cannot be beat, No one has the cylinder 03/04. 5 and software to run the Autos Better then Banks,The combination is unbeatable.
What about on a 2005 with the G56??
Thanks for the update guys...
Totally understand about the importance of compressor mounting location, as well as the differnces beteween compressor and vacuum actutated brakes... and obviously, I prefer the addtional utility of an added compressor...
BUT I have heard and read plenty of stories of problems with the PacBrake, like compressor failures, brakes stuicking open or closed, (though i must add also plenty of excellent feedback) and I actaully prefer to stay away from BD products in general...
So now my question is this, if this is not false advertising, how can Banks claim this,, even while using "old technology"
It looks as if Banks makes a better flowing when open and better braking when closed exhaust brake... how can that be... are they simply playing the numbers???
I run the Jacobs, which appears to be the same brake that Banks runs. I really like the "old" technology. And the only difference in the BD, PXRB and the Banks/Jacobs is the idle-2500 rpm braking, above 2500 rpms they are all the same, 60psi backpressure is the OEM limit, you can't get more braking without exceeding that. .
Which brings me to the retarding hp graph. . Banks can't make more retarding hp than stock as stock runs the max back pressure allowed by Cummins.
On the pre 06 auto's the Banks controller is great and would be my 1st choice if I were in that boat. . But on 06+ or manuals I think the OE ECM programming is the best, its programmed that way for a reason. . I 100% disagree with the programming that makes the brakes come on sooner, the 3 second delay is to save the turbo, sounds smart to me. At least where I live its not uncommon to go from 90% throttle, 1200* EGT's and 30+ psi of boost to running the exhaust brake in less than 1/8 mile, hence the reason I like the delay.
AH64ID, I am very curious... the actual Banks elbow is HUGE (have you seen the picture in TDR??) Is it really the same as the oem Jacobs ??
The Jacobs elbow is quite large as well. . Despite what Banks says, I cannot see a physical difference in the two.
