So I order a new MBRP exhaust, Banks Brake (for 4 inch exhaust) and AFE Stage 2 intake from Diesel Xtreme Performance. I do lots of research and make some calls in order to make sure everything is compatible.
When I go to install the brake, I realize that the Banks Down pipe must be spliced with the 4inch MBRP using a coupler. Major pain in the ***** but I say no problem, I'm up for the challenge.
Two days before the job I call Banks tech(lack of) support and ask them if the brake will fit into onto the turbo if there is a AFE stage 2 installed. The guy on the other end of the line while sounding sleepy and not very attentive said "no problem - it should fit fine. "
So, I'm ready to do my Banks install, and my father in law suggested that we try a test fit of the Banks brake to the turbo housing to see how it would fit up with the AFE. I put it on, put in 2 bolts to hold it in place and notice that the large black piston that closes the brake during operation is sitting right smack in the middle of the intake box opening (where the molded plastic hose connects to the box). There was absolutely no way I could make any modifications to the box to get it and the brake to work well with each other.
Thank goodness we checked that before I started cutting up the MBRP!!!
I guess my only option now is to return the Banks and exchange it for a BD. Hopefully the folks a Diesel Xtreme will be cool about it since they sold me the incompatible configuration. I'll let you all know how it goes!
SO, if any of you are thinking about getting a Banks exhaust brake and an AFE, think again.
BTW - the AFE and MBRP sound great together!
