It seems a little technical information about the High-Ram is in order. First of all, I should point out that we have never advertised or suggested that the High-Ram will increase horsepower by itself. It seems that the intent of the dyno run in question was to see an increase in horsepower. Although we do sell the High-Ram as a stand-alone item for those who consider themselves do-it-yourselfers, it is primarily intended to have an increased fuel calibration to go with it to take full advantage of the airflow improvement. It doesn’t really surprise me that you are seeing no power increase.
Now, about how to evaluate airflow improvement. As you are all aware, the Twin-Ram was designed to offer better airflow distribution to all six cylinders of the engine, but the configuration of the injector lines on the 24-valve did not allow a dual inlet configuration. But the stock inlet piece has a very sharp 90 degree bend in it that acts as a restriction. So we developed the High Ram to improve the entry path. The best way to evaluate the airflow improvement of a device like this is to measure pressure drop across it. For instance, when the engine is running at a given RPM with 25. 0 PSI boost on the inlet side, we measured 22. 5 PSI in the intake manifold, a pressure loss of 2. 5 PSI. At the same RPM with 25. 0 PSI boost going into the High-Ram, boost in the manifold was 24. 5 PSI, a pressure drop of only . 5 PSI. That means that while the engine/turbo is working to produce a certain amount of boost, more of the air density that is generated actually gets to the cylinders. That means that more fuel can be added to make more power.
Is the High-Ram the best possible design? No. If any of you have seen the intake configuration that we used on the Sidewinder project, you would know what is probably the most ideal intake configuration. We machined the entire intake trough off the side of the head and built a side draft manifold. This is obviously an involved situation that requires removal of the cylinder head and a lot of machining. The configuration that is in the Sidewinder is set up for the common rail engine.
