I am considering putting a exhaust brake on my 05 w/6spd. I have read some threads here about the pros and cons about some of the manufacturers. Banks claims much better exhaust flow with the brake OFF amd also much better braking horsepower than the other makers. Banks is quoting their own data, however, so you can believe it or not. I see from these threads here that many believe that Pacbrake makes the best brake for our trucks maybe because they use a air compressor instead of a vaccum pump. I wonder if Banks system has a good quality vaccum pump that will hold up in the long run? Please add your $. 02 on which exhaust brake is best and why.
