Thank you for reading and offering your experience...
01, 2500, 24V, 4X4 - Stock rear end and stock Trans.
last spring I installed a new Banks Power Pack boosting HP by 145 hours (Claimed by Banks) and +288 ft-lbs of torque (Again - claimed by Banks)
I see a drastic improvement al around to include pulling power, Gas Mileage (OK - Diesel Mileage) and all around power.
I have two concerns though and both were noticed through out camping season last year. I should point out here that the truck is a dedicated piece of equipment in my camping gear pulling a 14k lb 5th wheel @ 30 feet.
1. Heat: I find that on longer hills I have the power to climb but find that the temperature climbs too. I do not get any drop in HP or torque but my high heat light comes on and that concerns me. I back off to allow the heat to come back down but would like to add a solution. Help?
2. Trans: as mentioned it has the stock trans. I am sure the trans was not engineered to handle the +145HP so have considered several options. with the max HP gain is it neccesary to jump into a $3500 Suncoast high performance trans or will the stock trans be OK with a larger Magtech pan and an upgrade into a billet torque converter?
Anyone else go the route that I have?
Also added to the truck is a FASS DDR fuel pump.
Any and all comments are welcome.
