Banks PowerPak Fuel Plate on Ebay
Fender Flares
Wheel Cylinder Size on '99's
That's not like the TST 11 that I have. It looks more like an 8 but the main fueling ramp MIGHT be 11. I hear Banks is making their own plates now. Probably a good thing because my 11 isn't enough with the Twin Ram - at least not without sliding it WAY forward. Craig
I haven't seen the TST plate, so I can't say for sure which one it is closest to. I have been told by some people that it is very similar to a 10 (which I could easily believe due to the extremely high EGT's I say with it in the stock position). DBR recently sold one on Ebay as well and he said it was equivalent to an 11, so I went with the more conservative of the two choices. I know that I had to back it off about 50 thousands with the stock injectors to keep EGT's in line, and backed it off even more since I got the bigger injectors, so it seems to be a pretty serious plate.
The fueling profiles (ramp or whatever the proper term is) are the same. I traced them out on paper and they were identical. The only difference is below the fueling cure; the banks is cut back whereas the TST is straight. DBR
