rbattelle said:Give me a break. Anyone notice #9?
Okay, that's half true. The other half is that on a MASS basis (aka gravimetric), diesel has LESS energy content than gasoline. As far as I'm concerned, then, diesel has less energy content than gasoline; its lower heating value is lower than gasoline's.![]()
What is the coking temperature for a modern conventional oil? And what does the bearing type have to do with oil coking?
-Ryan
Bearing type may have nothing to do with coking of the oil when hot, but it is a fact that todays bearings are far better then what was in Turbos 30 years ago.
Todays oils are far better then they were 30 years as well, in the case of Royal Purple, it is designed to provide protection in high heat areas and to cling to metal surfaces, so even at shut down you would still have Royal Purple working for you in the case of the turbo spinning down, but I bet there are hundreds of thousands of owners who shut down with no cool off and their turbos have worked just fine.
You also get API rating with Royal Purple as well so if something should come up with your turbo and it is oil/bearing related, DCX can't refuse you warranty work, that is something Amsoil cannot say.
I think some of the problem is because the information came from Banks and for some reason there is a lot of hate toward Banks in hear.
I find it amusing that Banks even allows TDR into its shops for articles the way they get trashed in the TDR forums, for every one person who has a problem a problem with a Banks product I bet there are 20 others who have no problems.
