barb fittings
By-pass oil filtration kits-Which one? Need help choosing one.
Tow with Silver Bullet?
I"m having trouble pushing the barb fittings on 1/2 inch hose for the airdog. I"ve tried putting motor oil but have not been able to push them on flush to the hose. Any hints to help me out please.
PETE
i use pushloc fittings at work and they all seem to go in well. i usually put the fitting into the hose as far as i can get it by hand, then press it against a wall or work bench with the fitting against the wall/bench and both hands on the hose and push until the hose butts up against the collar on the fitting. . they go on like that pretty good even dry. .
Ideas I have done warm hose up usually on a hot day in sun. I have used spray, oil, petr jelly even used a heat gun new hose pending can be stiff some aren't as bad. you could talk to Vulcan compound turbo components, FireBall injectors, DrawStraw™, Big Line Kits, VP silicone boot kits, gauge installation components, metric adapters & fittings, FASS, Quadzilla, Edge,AirDog, DTT Trans, ISSPRO, HTT Turbo, AFE, Veg pumps,  brackets, they work with this stuff all the time different type of fittings they have a ton of fittings and lock style ones. good luck
