I just resealed the pump and I noticed there are a lot of little adjustments that could be made. The most important being the governor shaft that is blocked from adjustments once it is installed on the engine. The rest I can figure out later but I cant install this until I adjust the governor shaft first. Any ideas? The fuel screw I marked so that is ok. The linkage oops I did not mark any of thoes either but I can play with that later. And how about the "star" wheel? What does it do? I understand it changes spring pressure on the diaphram above it and boost pushes back but what does all this control? I assume fuel enrichment that is needed as boost increases. Is there a manual that gives these base line settings out there? What do the rebuilders use? And why is it important to lock the pump to install it?
Thanks for any help
Jason
Thanks for any help
Jason
