MMead said:
Once I get the elbow tapped, do I understand correctly that the probe should only be hand tightened into the hole? Seems like it would vibrate out pretty quick in that location.
JHardwick,
I noticed you said the hole should be "taper reamed". How do I go about doing that?
Thanks again.
As SRadke pointed out right below this question, the hand tight statement only referred to obtaining the proper thread depth. 3-3. 5 turns of handtight thread engagement should put you right on the money. After proper thread depth is achieved, and probe is installed, you will need to
snug it up with a wrench. Depending on thread quality, it could take anywhere from 1/2-1 full turn ... ... ... just don't armstrong it
I didn't mean to confuse you on the taper reaming thing. The minor diameter on the tap will cut the taper in the hole for you. The only time I take this step is when I am working with high temp and exotic alloys and other low machinability rated materials. The tapered reamer removes material so the tap doesn't have to and lessens the chances of tap breakage.
Ryan, the first picture showed a tap handle and the second picture showed a "T" handle. A lot of the "T" handles have a ratchet build right in them.
MMead, motor oil will work fine. This is a really powdery gray iron and could be tapped dry to be quite honest. The oils job is to eliminate galling which will "weld" the tapped material back onto the tap material. Iron is not ductile enough for this. Aluminum, stainless and some steels are really bad about galling. I remember tapping some exotic stainless for GE Aerospace and having a terrible time with it. Tapping in a machining center doesn't give you the opportunity to back the tap out, it just taps to a preprogrammed depth and thats it, you get what you get. Ripped up threads, broken taps etc etc. Well, this old boy over in the manual mill department was watching me ... ..... never said a word. He walked into the break room and came over and handed me a tub. Told me it was chicken fat that he kept in the freezer for times like this. I shrugged and lathered the tap with this stuff ... ... I had nothing to loose at this point, Id already tried every tapping fluid in the plant. Sure enough, that stuff was the bomb!! Worked like a champ!!
As for the wiring, I'm not real patient with stuff like that, but it went okay I suppose. My gages didn't need a constant power source, only power for back lighting. I pulled the head light switch out as far as I could and stripped about 1/4" of the orange/white wire (I think color changed in later years). Soldered my gage wires to it and taped it up.
