On my truck I mounted a radio shack relay and a 30 amp circuit breaker to the side of the clutch reservoir. I removed the "40 amp trailer" fuse from the PDC and used fully insulated . 250 quick slide terminals and # 10 wire to connect the rear PDC fuse terminal to the breaker, to the relay, then back to the front fuse terminal in the PDC. For ignition power to the relay I used the fuse tap on #8 fuse inside the cab that feeds my A pillar gauges. I stored the original 40 amp fuse in the "spare" location that only has one terminal in the PDC so if I have any problems I can unhook my wires and reinstall the fuse. Also the radio shack relay has the same terminal configuration as the factory PDC relays and will work as a spare in an emergency. I used the 30 amp breaker because I think the quick slides may heat at 40 amps and the Radio shack relay is only rated at 30 amps. My 8' pop-up camper only uses 12 amps with everything on so this works well for me, total cost was less than 15 bucks.
Jared
