FORD has the HEUI. GM has the same pump (or did in 02-03) as the new HPCR Cummins.
DP
Yep, if it had a Duraturd it has the same Bosch injection system as the Cummins. Still didn't start as well as the Cummins. :-laf If it cranked for that long probably had bad injectors, common problem with the early engines. All the electronic engines need at least 2 revoltions to synch the crank and/or cam sensor to know when to fire the injectors, about a 2 count if all is working good. Still nothing like the old 12V fire on the first piston up though.
Fords were the worst as the HEUI used oil pressure to fire the injectors and you had to spin it to get the pressure up enough to start it.
