Time to clean the battery posts.
For those that haven't been doing their own light duty maintenance, I will put forth a simple routine.
1. Collect together some tools and baking soda and Noxid Grease.
1/2" box end wrench, pliars or vise grips, Battery post cleaner brush, pencil wire brush, full size wire brush.
2. Wash the battery with a water hose, wire brush the excess corrosion away.
3. While the posts are still damp, pour on some baking soda and use a small pencil steel wire brush to work it in all the crevices. After the fizz stops, wash it away and repeat.
4. Disassemble everything. Remove the Negative Post First! Passenger's side, then the driver's side.
Use a pair of pliars or vise grips to slowly working the clamp bolts loose and pull from the cable post clamps.
5. Wash everything again and go thru the baking soda wash/scrub routine until all corrosion is gone.
6. Use a battery post wire brush cleaner to twist away all dark oxide coatings from the battery post terminals and inside the clamps.
7. Coat the terminals and clamps with Noxid Grease. Reassemble everything being sure all terminals are coated before assembly. After all is done, Cover all metal parts with grease to prevent future corrosion problems.
This simple procedure will normally give 4 to 5 years of life to your terminals in between cleanings. Normally all you have to do is wash the post/clamps off once a year and recoat with the Noxid. Adhered to faithly and your batteries will never have corrosion on the terminals AND your starter will thank you.
Caution: Never put stress on the battery posts when loosening/tightening the bolts. Back the bolt up with a wrench. Stressing the battery posts will cause cracks in the post-to-grid structure resulting in early battery failure.
Have a nice day.
Have a nice day.
