Matthew, no reason at this time you wouldn't go 04.5 style Injectors if you are doing stg 1's. As to modding the new Bosch negative! Do not have a new factory injector tampered with! Here is a little info on why:
(Direct Quote from Martin of BBi in Austria)
The pins are for proper alignment that is correct, but they are not designed to withstand any force on them. That is the reason a force must be applied on the nozzle body to increase the friction between the nozzle body and the injector body, prior to loosening or tightening the retaining nut. One must insure that there is not any torque applied to the alignment pins!
Is your torque wrench capable of measuring the torque and the angle at the same time? To start the angle measurement when a defined torque is reached and to tell you if one of both is not within tolerances?
If you do not have a torque wrench comparable to that one linked below with the same tolerances, you are not able to tighten a nozzle retaining nut correctly:
QuanTec electronic torque wrench / rotational angle wrench Gwk - Werkzeug Shop
http://www.toolsshop.ch/ch_en/quantec-electronic-torque-wrench-rotational-angle-wrench-gwk.html
https://www.toolsshop.ch/media/pdf/en/en655000.pdf
The second thing you need is something to apply a force on the nozzle body, do you have something for that? Building up a force which is high enough to not damage the alignment pins and the sealing surfaces during tightening?
Here is a video I found on youtube of a device for rebuilding injectors in the aftermarket. While not the proper equipment, it is better than having nothing for doing this procedure.
This is still not perfect because the force is not measured and not high enough to insure no damage occurs to the alignment pins or sealing surfaces.
https://www.youtube.com/watch?v=hNwITIAK6gk
First and foremost:
We only offer for sale, complete injector sets. We will not sell nozzle sets separately. Perfect quality can only be achieved with complete injector sets. Injector disassembly & reassembly outside of optimum clean room conditions often create their own problems. Common failures that can occur:
- High pressure Leakage between nozzle and injector body by using
incorrect torque values
- Mis alignment & contamination are common issues.
- High pressure Leakage potential due to damage to the high pressure
sealing surfaces.
All these failures can lead to a broken nozzle retaining nut
Failures by the injector itself will not be detected
Beside the possible failures we change all the necessary injector adjustment parameters to get the maximum power out of our nozzles.
http://www.bigbanginjection.com/products/
We are Common rail builders with a lot of experience, we are not telling anything that isn't true.
It is well worth it to step up to the BBi STG 1's from the Brand New Bosch. And one would want to think twice about any injector that is tampered with or not assembled in a factory clean room type setting using the proper equipment.
