Today my exhaust brake froze in the on position,and the egt's go thru the roof,I was two miles from home and figured I'd head to the shop,after manually moveing the arm and seeing that it wasn't stuck I tapped the solenoid valve case with channel locks and it shifted the spool. I removed the line and sprayed the inside of the solenoid valve with a little WD/40 and then turned it off/on several times. Has any one else had this happen?One note, a man should keep a short length of wire so if for some reason the brake won't turn off ya can tie it open becuse you can not drive with any rpm like this. Sorry so long.
