Did the governor spring kit today and I agree with the other guys about a very touchy throttle tip in,and the egt in fifth gear go thru the roof I can' go to full throttle any suggestions?One note about the install not as bad as I feared but time consuming but it tells you in the instructions to measure the distance from the top of the stud to the nut before disassebly this was impossible I got a different reading every time and I had a digital slideing caliper,bottom line is there is no way that I got it exactly like it was. I didn't get the valve springs installed yet so I will have to use a light foot but 3500 rpm is easy in the lower gears,I guess a call to Piers monday is in order.
