BD gov spring kit "help Piers"
Another towing capacity question
Leaking steering gear box...
Did the governor spring kit today and I agree with the other guys about a very touchy throttle tip in,and the egt in fifth gear go thru the roof I can' go to full throttle any suggestions?One note about the install not as bad as I feared but time consuming but it tells you in the instructions to measure the distance from the top of the stud to the nut before disassebly this was impossible I got a different reading every time and I had a digital slideing caliper,bottom line is there is no way that I got it exactly like it was. I didn't get the valve springs installed yet so I will have to use a light foot but 3500 rpm is easy in the lower gears,I guess a call to Piers monday is in order.
Ramguy
Check my latest thread "Gov spring kit install, easy,easy". I adjusted the locknuted allen screw on the end of the AFC in about 4-5 turns and cleared up my same problem. Now drives like stock but more power. I'm very happy.
1972 Chinook class C with 96/215 5spd, 4/5" exh, 4"BD, MagHytec, 85gal fuel, K&N RE0880, AutoMeter, 370's, BD gov kit, BD afc kit, yada-yada-yada
www.fostertruck.com/cummins
ramman what cam plate are you running, what position is it in, what spring are you running in the afc housing & where do you have the afc housing located???? Here's how it should be, cam plate in the stock or back of stock position, medium afc spring, afc housing 3/4 of the way forward, star wheel "about" 1/4 of the way back. Some of the cam plates have quite the angle cut in them [ bottem part ] and the arm thats supposed to ride on the cam plate will slip underneath, giving one big bottem end fuel, then depending on the cut & position of the cam plate the arm will start climbing out from under the plate, giving a drop in power, then go over to where it's supposed to be & then all **** breaks loose as the fuel starts coming back on #ad
Give me a call on Monday if you have any questions 1-800-887-5030
