BD super B special turbo
Best Tuner/Gauge combo for 2017
Love message from my truck "Service DEF system See dealer"......
A good buddy of mine has a 2010 3500 6spd G56. He started out with an H & S programmer which he ran on mild most of the time. He popped his head gasket a few years ago. When he had that replaced and studs installed he put in a cam. It made a huge difference, low EGT (dropped 200+ F) better fuel economy and more hp. This past year he had his VGT turbo quit. And as he had done before (on his 08 that he had) he ordered up an aftermarket turbo. This time he bought the kit from BD with the super b special. He isn't so fond of the turbo. It has higher EGT to the point he has to get off the skinny pedal even when he's not pushing the truck. He had very low boost. I suspected the wastegate was opening on him. I got him to clamp off the wastegate line with vise grips and run it and his boost and EGT were a bit better. He set the wastegate to 38 psi I believe. He still has an EGT issue.
The specs on BD super b special are 64 compressor/ 71 turbine with a 14 cm housing? The turbo he ran on his 08 was only a 62 on the compressor and didn't have an EGT issue. It was a silverbullet turbo 62/71 14cm? It was a reg cab 6 spd truck.
what might be his problem? The engine breathes too easily with the cam to light the turbo? Bad turbo? Would a 12cm or 13cm housing give him more boost and lower EGT? He tows a lot with this truck and would like to drive it without watching the EGT like a hawk.
thanks
The Special is a very big turbo for high HP use, not general purpose use. BD has other choices; contact them. A big turbo will be slower to build boost and that increases egt except when high power is being used to spool it up.
If you go to several vendor websites they recommend the Special for 6.7L applications. It's in their VGT delete kit with an exhaust brake. My buddy has contacted BD and they don't seem to want to make things right. The vendor that sold him the turbo has a good reputation and offers sound advice. My guess is there is something a bit off with this turbo. The wastegate wasn't set correctly when he first installed it and it would open at 25 psi. I have to watch my EGT closely on my trucks it's not fun. I hope the 351VE turbine wheel solves my problem.
