2nd Gen Non-Engine/Transmission Bearing/Hub replacement for 96 3500 4wd
Need help guys.
Long story short had some front work done on my truck and 2 weeks ago, the right front hub/bearing assy went bad. Now the left front is going. I figured this was gonna happen. I need a good replacement that doesn't cost silly money. I can't afford the EMS conversion right now. There seems to be a bunch of options out there on the internet ranging from $220 to more than $400. Anyone have experience with a brand that has worked?
That's some funny stuff. Shop that did the initial front end work replaced it with a NAPA part for $381. I didn't even ask them to do this. I just asked them to take a look at it. Total bill was $550.
For those shaking their heads as to why I didn't go in there screaming bloody murder... . Just sick of the fight that comes of this kind of thing. You can bet your bottom dollar though I will check and see if there was a "mark up". If there was, I will be paying them a none to friendly visit!
What did they replace?
If you want to set up a time in the evening/weekend, I could replace the hubs for you. Not to bad to do. I'm only about 45 minutes away from you.
Maybe Seisenbath gets a good discount, here is what napa online sells for.
NAPAONLINE®
The job is not bad if it comes apart and is not rusted tight, even then a little finesse and it will come. Make sure to use plenty of anti seize and if you ever have to take it apart again, it will almost fall off.
I bought mine at Advance auto, they had a lifetime warranty at the time, but i just looked and it is now showing 1 year.
I just did these on my 97 and found a guy on Ebay selling real Timken Bearings, both sides to my door for $315. Best I could find and this included new wheel studs.
Here's a link to the deal I found... . maybe he's got more.
Timken HA590020 Axle Bearing and Hub Assembly 94-98 DOD:eBay Motors (item 180331784763 end time Mar-26-09 13:54:50 PDT)
Chris
Just spoke with Alfredo at the above who was very helpful. His number and extension is 516-678-3900 ext 3229. I have no interest in his company and am not affiliated in any way. He was very helpful and this can be a rarity...
