Bed liners
bug shield - front end protection
Dodge Factory Wheel Flairs
Has anyone used any of the do it yourself bed liners like Herculiner and if so how long have you had it on and how is it holding up? I am at the point of doing something else besides the slip in bed liner, kind of tired of everything sliding around in the bed but I am reluctant to spend the $400. 00 to $500. 00 for the sprayed in liners.
Thanks,
Paul
'96 2500 ext. cab, LB, 4x4, 5 speed, 3. 54, TST 280 cam plate, AFC spring kit ,pyro and boost gauges mounted on A-Pillar
I shopped the spray in guys Flatlander & did the Rhino on the 95 & did Diamond Liners on the 96. The Rhino was ~$450 & the Diamond was ~$325. Things slide a little more on the Diamond liner. The Diamond Liner is not as good as the Rhino. The Rhino didn't give as much when you walk on it. I think it's due to being a little thicker, but definately a different material. My vote would be to have a good quality spray in done & shop the price & go see one after they do it. Mucho better than the do-it-yourself. One of the daughters boyfriends did it & it looks good for awhile, but is no-where as durable. By the way, get it sprayed over the top of your bed rail. #ad
Money Sink - 96, 5 speed, SLT, 4X4, LWB, Ext Cab, ISSPRO pillar, TST 280/685 all the way forward, AFC housing all the way forward, Delvac 1 & Amsiol, Injectors, K&N, Monicas silencer ring removed, Exhaust brake, 4" CAT back & CATless, 4" chrome turn down straight out back, Mag-Hytec, 3:54, 235s.
I'm with Forrest, the extra few bucks are worth it to have it done professionally. The guarantee is nice too. I had Rhino liner sprayed in mine 4 years ago. I can tell you it is tough stuff. I would suggest doing any mods to your bed BEFORE spraying it in though. I made the mistake of spraying it in before installing the camper kit. Had to use a die grinder to notch it out to fit. Made a easy install a pain. I always have something banging around in my truck bed and it still looks good. I also have a rubber mat on the bed which virtually eliminates slipping around. I will never have a slip in bedliner again.
