If it is indeed an extended warranty solution....... which if coming from Sag2, it is a likelihood because he usually has good sources..... I wonder if the turbo cool down idle time recommendation suggested in the diesel supplement manual will also be changed to increase the turbo cool down times to keep the actuator from overheating?
My derated 2013 (660 ft lbs torque) has had no turbo.or actuator issues. Then again, the programming doesn't pull as much boost as the automatics because of my g56 equipped and torque/power derated Cummins.
