04. 5 Dually with 58,000 miles. I replaced the fuel filter, doing it myself for the first time. I used some directions from another site that worked out pretty well, until it came to starting the truck. It said the best way to refill the fuel filter canister was to bump the starter until you heard the lift pump go silent, do it once more, and start the truck. Everything went to plan, truck started right up after doing the bump thing, then I heard a flap flap flap noise, shut it down and saw that my belt was shredding. :{ So, i got it replaced but now I'm wondering if the two starter bumps caused the belt to slip or if it was just an amazing coincidence. And if it did cause the belt to slip, is there a better way to prime the system?
Thanks - Scott
Thanks - Scott
