joemyers said:Like I said, you are probably not old enough to know. Chebby trucks back in the fifties were basically a car frame with a pickup bed, they did'nt even compare to a GMC. You should dig a little deeper in your history. I was there, you obiviously wern't.![]()
Matt400 said:How does a higher reving bigger cubic inch V8 get better mpgs than a smaller lower reving 6?
There is some of the difference, I get 19. 5 empty on mountain roads, haven't checked it on the freeway and 14-16 towing 6000 depending on the grades.Camp said:The Cummins gets 15-17 empty and 10-12 pulling that load.
Matt400 said:There is some of the difference, I get 19. 5 empty on mountain roads, haven't checked it on the freeway and 14-16 towing 6000 depending on the grades.
nickleinonen said:the new ones are 605 torque... and the gm torque management defuels in 1 and 5... in 1 you don't need full torque [gearing multiplication], and in 5, you can't put full torque down as most slushbox will downshift... the chevy trucks are very nice i think. . the IFS doesn't bother me. i don't like trucks that sit way high up. if i had to get a truck with an automatic, the dmax is something i would look at [straight out of the box, the best auto i think]... i don't like that the manual trans with the dmax is still the old trim [300/520]
CLAYTON said:I can't believe that no one has posted this pic of the famous connecting rod yet... so I guess I'll go ahead and post it... Take a look at the difference it goes Chevy. . Ford... then Dodge. And they say size doesn't matter :-laf
Didn't know that, thats a disappointment for sure.OHale said:If you select the shortbox you have only 25 gallons of fuel.
hasselbach said:Has anyone actually heard of anyone throwing a rod out of a duramax, especially a hot rodded one? I sure haven't.
Since the dodge is a 6 vs. the V8 design for the ford and chevy, it stands to reason the dodge connecting rod would be somewhat bigger. I've seen some d-max motors post over 700 hp on stock rods.
