best bomb to purchase first?
BD not allowed in the US
Allison trans for a Cummins
With father day approaaching..... what is the best bomb I can get for $200 and under?
Frank
01 White, Quad Cab,Short Box ,Sport SLT+,5 speed 3. 54 Ltd-slip,4X4,line-x ,Nerf bars,fiberglass tonneau cover
Best bomb under $200 would be a Psychotty or other type of air filter upgrade. Close behind that ($250-$275) would be a boost and pyro gauge, with A-pillar mount.
Greg
Y2K Dodge Cummins QC 2500 SLT Laramie 4x4 Long Bed, 4. 10/Auto, Forest Green/Driftwood, 265x75R16 Michelin LTX, 6 speaker CD, Camper/Tow/Plow Packages, Westin Black Nerfs, Mopar bedliner, Ultra bright diamondplate toolbox, K&N Filtercharger, Autometer Ultralite EGT and Boost gauges in 2-gauge pillar w/tweeter, DD Stage II injectors, boost module, and boost elbow. Yee haw!
http://www.rints.com/hammond for photos!
Gauges should be added first regardless of price. Quality boost and pyrometer gauges (all you would really need in your case) can be purchased for $200. -$250.
Like John said,
boost and pyrometer gauges are definitely the start. I got mine from TST Products and they have worked flawlessly. Then, go for one of those computer chip performance boxes you 24 valvers use. #ad
1997 2500 ST 4x4, 5-speed, 4. 10 axle, TST 60lb boost @ EGT gauges, TST #12 230hp/605ftlb plate & AFC Spring kit, limited slip axle, Amsoil air/oil filter & oil. Jardine 4" turbo back exhaust.
Dido on the gauges !!
96 2500 4X4, SC, SLT, 12 valve,lost kitty, silencer ring gone, 5SP 3. 54. dana 80, Pac Brake with 60 pound valve springs, line-x liner, Auto meter ultra lite boost and pyro gauges on A pillar,
guages will tell you things that the "seat of pants" just can't give accuracy on. It wasn't my 1st BOMB, but they went in with the injectors and plate for sure.
first BOMB of any consequence was actually the valve body, but that won't fall into your $200 limit.
mildly BOMBed 98. 4 1B7KF23D4WJxxxxxx-- BD's #5 plate and 210HP injectors--BD Brake and the associated transmission bomb goodies (except for TC,currently), 4" open exhaust (short),Psychotty, camper shell, Warn front receiver, G159Unisteels on Rickson 19. 5's. . CD player is bone stock, so are the seats. PrimeLoc, also remote spin-on filter for the auto trans... Pyro,Boost and Trans temp from Isspro,
Westin nerf rails(black),MagHytec Cover on the Dana 70 and on the transmission. (tire hangs a little further aft for clearance)
bent welding rod to hang celphone on dashboard...
240HP on Dynojet from 75-105mph drumspeed.
calculated 721 lbft @ 1800rpm
Gauges, get a baseline.
2001. 5 2500 QuadCab SLT, Auto, 3. 54 Anti-Spin Axle, 4X2, SWB, White/Tan, Stockland Camper, Interior kit, Debadged, Custom CUMMINS Logo Sticker, SPA Gauges Pillar Mount, Magtech transmission Pan and Rearend Cover, Front Spoiler, Sport Tail Lenses, Valentine One, HX 40 and 16cm turbo, DD2's, 4 inch exhaust and down pipe with two muffles from DD, Diesel Dynamics' New Ultimate Power Module, Psychotty Air Box, DDT 91 TQ and VB, transmission blueprinted by DD.
www.ProwlerOnline.com
View my Cummins Sticker
