Sorry, I cannot read uour signature on my phone. But if you have a 94- 99, I would do a Ford hub conversion that will give you dual piston calipers from a 92-94 F350 or 95-97 F350 (even better). If you have a 00-02, then you can easily upgrade to 2011 (maybe even later) Dodge 3500. That will give you even bigger calipers and rotors.
As far as rotors, most parts stores rotors are going to be similar. When you get into cryoed and slotted rotors, you should see an improvement in resistance to warping. I would stay away from drilled and slotted rotors. You will lose braking due to the loss of surface area. They also have a tendency to break (no pun intended) Lol!
For pads, I have gone through probably 30 sets prior to my conversion, so I have owned almost every brand and style. As would be expected, any of the premium grade pads were the best, and that goes for the premium store brand as well. Just stay away from the lifetime warranty pads. They are hard as steel and will tear up your rotors. Hope this helps. Good luck.
