Engine/Transmission (1998.5 - 2002) Best combo with the Drag Comp.....
I currently have a Drag Comp but would like to stack a chip with the comp. Which is the best chip to stack with the drag comp?
I did not know it was possible to stack anything with the comp. Unless the wire was disconnected and it was only used for timing.
I tested a Catcher "Special" with my drag comp. That was a riot!! I am waiting for an ECM so I can do that stack.
Dave
I didn't think you could stack anything with the Comp with a pierced pump wire either. If you want to stack something and have the pierced wire with the Comp (that is more than just timing adjustments), I would recommend a special CATCHER.
Otherwise, I think you would have to have the Comp in timing only mode, which kind of defeats the purpose of having the Comp as it essentially acts like an EZ then.
Pointless, I would have to agree that if you want more then get a "Special". The timing and wire tap are already in the Comp... ... ..... :D
