As opposed to replacing your lift pump and counting the days to the next failure, you could replace the lines and fittings with parts that provide improved fuel flow. You could also, mount your replacement pump on the frame rail back by the tank, then the pump will work more as it was designed to. DCX sourced the lift pumps from Cummins, speculation is that DCX wanted them mounted to the motor to make it easier on themselves. Additionally, you could leave a 15psi (factory) pump in it's original location and add a 7psi pump to the frame. The lines, fittings, and relocated/additional pump setup has provided a considerable improvement over the factory setup to many people here on the TDR. Depending on how much of your own effort you want to provide, this setup should cost you between 1/6th and 1/2 of what a high end system will run.
So in a nutshell:
A) You can spend between $100 (+ replacing your failed pump) and $500 for DIY to kit solutions
B) Purchase a high quality electric pump system (with plumbing?) in the $600 range
C) Spend upwards of $1000 for a mechanical system (with plumbing).
Scotty, as with numerous others, sell the plumbing/pump kits (A), there are also numerous vendors selling the high end electric systems such as FASS (Fuel Air Seperator) or AirDog (similar to FASS or vice versa depending on who you ask) (B), and a couple of vendors such as DTT or PBP dealing the mechanical RASP system (C).
Good Luck!
