I was over at a 4x4 shop and they told me the Dana Powerlock was a good setup... . Now it has clutch packs... ... thoughts on these... ... or what is the best ?????
What's best REALLY depends on how you will use it. The Dana powr-loc is a good unit. It does use clutch packs to distribute the torque. The bad part about clutch packs is that they will wear out eventually. How long they last really depends on your driving and maintenance habits. For example, around town driving will wear the clutches faster than highway driving. The good part is that you can re-stack the order of the clutches and plates to custom tailer how agressive you want your limited slip to be. We really need to know how you will be using the truck in order to recommend the best traction aid. That said, for anything other than extreme use, you can't go wrong with a powr-loc.
Another option is a Detroit Tru-trac. The torque bias is similar to the powr-loc, but it uses gears instead of clutches.
