Best Method for Changing Transmission Fluid
Banks vs Smarty
48RE hunting
Hello Ya'll,
Question from somewhat novice.
I have a 2004. 5 Ram (140K mi. ) that I bought used one year ago.
It recently came to my attention that the I needed to have the transmission fluid replaced.
I heard a nightmare from someone who did it the wrong way and ended up getting metal shavings into the transmission... resulting in disaster. The local lube shop says they have a method of just sucking it out and then replacing the fluid. I definitely want to make sure that its done the right way.
Any advice?
Also have to replace differential fluid... but I am assuming that is fairly straightforward.
Thanks in advance,
Mike
Here is "LINK" to a good procedure for changing out the Automatic transmission fluid:
https://www.amsoil.com/faqs/ATF_and_Filter_Change_Procedures.pdf
I have doen this for several years.
