Best mild box for 2003.5 Auto?
Di Pricol installation instructions
Any 305/555 Juice owners experience this...?
I go up to the mountains in the winter and below zero is common and do not want to be stuck like this. I was considering a mild pressure box not wanting to over-bomb it yet. Has anyone with a pressure only box had this happen? I bet it was just a loose connection or weak solder - physics get weird once you go below zero!!!
I have a DRB III ,I would have to agree about Banks Marketing of their Six-Gun,Since we service all three GM,Ford,Dodge, we must consider the product application for the three. We don"t use the dyno much around here(NASCAR Doesn't"t either) when I did My 03 SO Dodge Program stock turbo/ with ATS complete 343 RWHP, Now with my stock 330 Cummins Program. 425 RWHP 850 TQ.
Well, it seems this thread is going down hill. If you have a personal problem with anyone's post whether it be CB or mine is better than yours, :-{} you need to carry that problem on via email or off site.
Any other post that seem to go astay from the original post will be deleted.
Thanks
Brandon :)
Quadzilla works for me...
I had the Edge EZ and got a chance to Beta test the Xzillaraider module. I found it to be smoother on the power than the Edge and also had a smoother idle. I would not ever say the Edge is not a good box, because it is, I just stuck with the Xzillaraider because it works best for me. I tow a 11K 5th wheel quite a bit and the extra power has come in handy. I have the standard module (30, 60, 100hp) and I keep it on the 60hp setting all the time.
Just thought I would put in my nickel's worth.
:D :D
I ran the Qzilla module as a Beta tester and had no trouble with my CB whether the linear was on or off. Unless they've changed something since then that is definitly not a 100% of the time problem. My advice for a mild box... . TST settings 1 through 3.
-Scott
