Engine/Transmission (1998.5 - 2002) Best Oil Filter Wrench?
Engine/Transmission (1998.5 - 2002) Ok to burn ATF?
Engine/Transmission (1994 - 1998) fuel anti theft switch?
What is the best tool for getting the OEM oil filter loose?
Have been through 2 standard oil filter wrenches, and I remember there was a TDR member (machinist) in the past that made up some custom wrenches for members. Wishing I had bought one of those. :rolleyes:
Just looking for any new suggestions - Thanks!
I use Craftsman strap wrenches if I can't get it off by hand. Wrap the rubber band around the filter, lock it into the handle, and turn.
When all else fails, I use a BFH and screwdriver! :D
I have an ancient oil filter strap wrench that I bought for my 65 Mustang when it was new. :eek: I've never had a problem getting an oil filter off with it - even the filter originally installed on the truck at the first oil change. ;)
Rusty
Gives great mechanical advantage
http://www.lislecorp.com/tool_detail. cfm?detail=1104
I'm surprised this tool is not offered in Geno's Garage catalog. I've had one since buying my truck in Nov. 1999, purchased at my local parts jobber. It requires use from the bottom with an extention and ratchet wrench (can you say creeper) and will work on auto equiped trucks. FYI; I'm amazed at how awed and gungho everybody was by the fluted filter that was incorporated on the 3rd generation trucks. You'd think it was the first time a manufacturer fluted a filter. GIVE ME A BREAK. Get a Lisle; nuff said.
Oil Filter Initiation
I would think you had this figured out by now ;)
I got the one pictured in this article Oil Filter Initiation from an AutoZone store. With this strap wrench, you can work comfortably from the top of the engine with a great big 1/2" socket handle. I often deform the outgoing filter, but who cares.
Cheers,
Neil
Looks pretty good. Actually tried something like this before but it ended up breaking. Dont think its quality was as nice as this one is. . Definitely an option.
Cheers,
Neil
This looks pretty simple and durable. Also like the ability to use a long 1/2" drive ratchet from the top. Going to try one. .
Thanks for the suggestions!
I have a 30 year old strap wrench from Sears that has a hinged handle. Works on everthing I've come accross.
Wiredawg
$47 for the best oil filter wrench
A good friend who is a diesel mechanic and has lots of experience with heavy equipment and farm equipment got me hooked on a pair of slip-joint pliers that are slightly angled. They are SNAP ON brand. They fit everything from cars to pickups to big trucks to earthmovers. A little pricey but well worth it.
