AH64ID
This was not mentioned, When post tubo installed you have to keep in mind a temp difference of approximately 300* cooler than pre tubo. The cooler temp looks cool but you don't want the piston to get above the 1250* and get damaged. A lot of PRO & CON. OTR trucks have them post. They are working harder than ours. And the 5-6 area is your hottest spot.
It was mentioned, and the small housings on the HE341 and HE351 make for a less predictable variance, so 300° doesn't always work. On older, or aftermarket turbos that have properly sized turbines then 300° guess is better, but still not accurate.
Even pre turbo has it's flaws, as timing plays a huge role in EGTs. 1450° might be fine on a 2005, but might melt a 2003.
