Best Scanner for 6.7, another CEL Dealer=$105
Regen issues solved yet?
Difference between 08 and 09?
I was wondering what you guys prefer and where you purchased it? I have a 99, 98, 2001 and the infamous 2007 with the 6. 7. My check engine light came on for one day and disapeared and I parked the truck until I got back from Florida, drove it down to the dealer and they are charging me $105 to read the scanner code while its down there getting the darn thrownout bearing replaced. I saw one for about $180 at Autozone and looked like it would read all of my 5. 9 cummins older trucks but was not sure if it reads the 2007 with th3 6. 7??? What is the best reader out there if you were to recomend one to buy for all of my trucks including the 6. 7 3500 4x4 I have?? Thanks for any replys in advance.
I bought a Innova 3130 on line for a little over $100. This will work with any vehicle that has an OBD II port from 1996 and on. I am very happy with this unit and has done everything I needed.
This was recommend to me from some one on this forum back in Jan 08. You can buy this on line either from Amazon .com or do a search for other sellers on line.
A trip to the dealer might yield you a reflash to bring it's software up to date. The reflashes seem to have reduced the problems.
If you just want to read the codes, you can use the key on/off/on/off/on trick. Don't start the engine, just cycle the key 3 times, leaving it on the third time. You need to do it quickly (under 5 seconds for the whole process). The codes appear in the odometer window, one after the other, followed by "done". There's a list of codes and what they imply is wrong on the forum somewhere.
I'll post'em here.
P000f Fuel System Over Pressure Relief Valve Activated
P0016 Crankshaft/Camshaft Timing Misalignment - Bank 1 Sensor 1
P0031 O2 Sensor 1/1 Heater Circuit Low
P0037 O2 Sensor 1/2 Heater Circuit Low
P003a Turbocharger Boost Control Module Position Exceede Learning Limit
P0046 Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance\
P0049 Turbocharger Turbine Overspeed
P0069 MAP/BARO Correlation
P006e Turbocharger Boost Control Module Supply Voltage Circuit Low
P006f Turbocharger Boost Control Supply Voltage Circuit High
P0071 Inlet Air Temperature Sensor Rationality
P0071 Ambient Air Temperature Sensor Performance (TIPM)
P0072 Inlet Air Temperature Sensor Voltage Too Low
P0072 Ambient Air Temperature Sensor Circuit Low
P0073 Inlet Air Temperature Sensor Voltage Too High
P0073 Ambient Air Temperature Sensor Circuit High (TIPM)
P007c Charge Air Cooler Temperature Sensor Circuit Low
P007e Charge Air Cooler Temperature Sensor Circuit High
P007e Charge Air Cooler Temperature Sensor Circuit Intermittent/erratic
P0087 Fuel Rail Pressure Too Low
P0088 Fuel Rail Pressure Signal Is Above Max Limit
P00af Turbocharger Boost Control Module Performance
P0096 Intake Air Temperature Sensor 2 Circuit Range/Performance
P0097 Intake Air Temperature Sensor 2 Circuit Low Input
P0098 Intake Air Temperature Sensor 2 Circuit High Input
P0101 Mass or Volume Air Flow Circuit Range/Performance
P0102-mass Air Flow Sensor "a" Circuit Low
P0103 Mass or Volume Air Flow Circuit High Input
P0106 Air Pressure Sensor Rationality
P0107 Manifold Absolute Pressure/BARO Sensor Low Input
P0108 Manifold Absolute Pressure/BARO Sensor High Input
P0111 Intake Air Temperature (IAT) Sensor Rationality
P0112 Intake Air Temperature (IAT) Circuit Low Input
P0113 Intake Air Temperature (IAT) Circuit High Input
P0116 Engine Coolant Temperature (ECT) Sensor Rationality
P0117 Engine Coolant Temperature (ECT) Circuit Low Input
P0118 Engine Coolant Temperature (ECT) High Input
P0128 Thermostat Rationality
P0131 O2 Sensor 1/1 Circuit Low
P0135 O2 Sensor 1/1 Heater Performance
P0137 O2 Sensor 1/2 Circuit Low
P0141 O2 Sensor 1/2 Heater Performance
P0148 High Pressure Common Rail (HPCR) Fueling Error Checksum
P0169 Water In Fuel (WIF) Light On Too Long
P0191 Fuel Rail Pressure Sensor Performance
P0192 Fuel Pressure Sensor Voltage Too Low
P0193 Fuel Pressure Sensor Voltage Too High
P0196 Engine Oil Temperature Sensor Circuit Range/Performance
P0197 Engine Oil Temperature Sensor Circuit Low Input
P0198 Engine Oil Temperature Sensor Circuit High Input
P0201 Injector #1 Control Circuit
P0202 Injector #2 Control Circuit
P0203 Injector #3 Control Circuit
P0204 Injector #4 Control Circuit
P0205 Injector #5 Control Circuit
P0206 Injector #6 Control Circuit
P0217 Decreased Engine Performance Due To Engine Overheat Condition
P0219 Engine Overspeed Condition
P0230 Fuel Pump Primary Circuit
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0234 Turbocharger Over-boost Condition
P0236 Turbo/Super Charger Boost Sensor A Circuit Range/Performance
P0237 Turbo/Super Charger Boost Sensor A Circuit Low
P0238 Turbo/Super Charger Boost Sensor A Circuit High
P0243 Wastegate Pressure Control PWM
P0251 CP3 Pump Regulator Control
P0261 Cylinder #1 Injector Circuit Low
P0262 Cylinder #1 Injector Circuit High
P0263 Cylinder #1 Contribution/Balance
P0264 Cylinder #2 Injector Circuit Low
P0265 Cylinder #2 Injector Circuit High
P0266 Cylinder #2 Contribution/Balance
P0267 Cylinder #3 Injector Circuit Low
P0268 Cylinder #3 Injector Circuit High
P0269 Cylinder #3 Contribution/Balance
P0270 Cylinder #4 Injector Circuit Low
P0271 Cylinder #4 Injector Circuit High
P0272 Cylinder #4 Contribution/Balance
P0273 Cylinder #5 Injector Circuit Low
P0274 Cylinder #5 Injector Circuit High
P0275 Cylinder #5 Contribution/Balance
P0276 Cylinder #6 Injector Circuit Low
P0277 Cylinder #6 Injector Circuit High
P0278 Cylinder #6 Contribution/Balance
P0279 Cylinder #7 Injector Circuit Low
P0280 Cylinder #7 Injector Circuit High
P0281 Cylinder #7 Contribution/Balance
P0282 Cylinder #8 Injector Circuit Low
P0283 Cylinder #8 Injector Circuit High
P0284 Cylinder #8 Contribution/Balance
P0297 Vehicle Overspeed Condition
P0298 Engine Oil Overtemperature Condition
P0299 Turbo/Supercharger Under Boost
P0300 Random Misfire Detected
P0301 Cylinder #1 Misfire Detected
P0302 Cylinder #2 Misfire Detected
P0303 Cylinder #3 Misfire Detected
P0304 Cylinder #4 Misfire Detected
P0305 Cylinder #5 Misfire Detected
P0306 Cylinder #6 Misfire Detected
P0307 Cylinder #7 Misfire Detected
P0308 Cylinder #8 Misfire Detected
P0335 Crankshaft Position (CKP) Sensor A Circuit
P0336 Crankshaft Position (CKP) Sensor A Circuit Range/Performance
P0337 Crankshaft Position (CKP) Sensor Voltage Too Low
P0338 Crankshaft Position (CKP) Sensor Voltage Too High
P0340 Camshaft Position (CMP) Sensor A Circuit (Bank 1 or single sensor)
P0341 Camshaft Position (CMP) Sensor A Circuit Range/Performance (Bank 1 or single sensor)
P0381 Glow Plug/Heater Indicator Circuit (Wait To Start Lamp Inoperative)
p0400 Egr System Flow Mali Function
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Control Circuit
P0404 Exhaust Gas Recirculation Control Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P040b Exhaust Gas Recirculation Temperature Sensor 1 Circuit Performance
P040c Exhaust Gas Recirculation Temperature Sensor 1 Circuit Low
P040d Exhaust Gas Recirculation Temperature Sensor 1 Circuit High
P0420 Catalyst Efficiency Bank 1
P0460 Fuel Level Sensor A Circuit
P0461 Fuel Level Unit No Change Over Time
P0462 Fuel Level Sensor A Circuit Low Input
P0463 Fuel Level Sensor A Circuit High Input
P0470 Exhaust Pressure Sensor
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low Input
P0473 Exhaust Pressure Sensor High Input
P0477 Low Voltage On The Engine Brake Driver
P0478 High Voltage On The Engine Brake Driver
P0480 Fan 1 Control Circuit
P0483 Fan Speed
P0487 Egr Airflow Throttle Control Circuit A Open
P0488 Egr Airflow Throttle Control Circuit Performance
P0489 Egr Control Circuit Low
P0500 Vehicle Speed Sensor A
P0501 Vehicle Speed Sensor 1 Performance
P0513 Invalid Skim Key
P0514 BAT Temperature Sensor Rationality
P0516 Low Voltage At The BAT Temp Sensor
P0517 High Voltage At The BAT Temp Sensor
P051b crankcase Pressure Sensor Circuit Range/performance
P051c Crankcase Pressure Sensor Circuit Low
P051d Crankcase Pressure Sensor Circuit High
P0521 Oil Pressure Switch Rationality
P0524 Oil Pressure Too Low
P0528 Fan Speed Sensor Circuit No Signal
P0532 A/C Sending Unit Volts Too Low
P0533 A/C Sending Unit Volts Too High
P0541 Low Voltage On The #1 Intake Air Heater Relay
P0542 High Voltage On The #1 Intake Air Heater Relay
P0545 Exhaust Gas Temperature Sensor Circuit Low - Bank 1 Sensor 1
P0546 Exhaust Gas Temperature Sensor Circuit High - Bank 1 Sensor 1
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise Control ON Signal
P0566 Cruise Control OFF Signal
P0567 Cruise Control RESUME Signal
P0568 Cruise Control SET Signal
P0569 Cruise Control COAST Signal
P0572 Low Voltage Detected At The Brake Switch
P0573 High Voltage Detected At The Brake Switch
P0580 Low Voltage Detected At The Speed Control Switch
P0581 Low Voltage Detected At The Speed Control Switch
P0585 Speed Control Switch 1/2 Correlation
P0592 Speed Control Switch 2 Circuit Low
P0593 speed Control Switch 2 Circuit High
P0601 internal Memory Checksum Invalid
P0602 Checksum Error
P0603 Internal Control Module CAM Error
P0604 ECM Software Error
P0605 Powertrain Control Module Read Only Memory (ROM) Error
P0606 ECU/PCM Processor
P0607 ECM Internal Failure
P061a Etc Level 2 Torque Performance
P061c Etc Level 2 Rpm Performance
P0611 Fuel Injector Control Module Performance
P0620 Generator 1 Control Circuit
P0622 Generator Field Not Switching Properly
P0623 Generator Lamp Control Circuit
P0628 Low Voltage Detected At The Fuel Lift Pump Relay
P0629 High Voltage Detected At The Fuel Lift Pump
P062c Etc Level 2 Mph Performance
P0630 VIN Not Entered Error
P0633 SKIM Secret Key Not Entered
P063c Generator Voltage Sense Low
P063d Generator Voltage Sense High
P0642 Low Voltage At The #2 Sensor Supply Circuit
P0643 High Voltage At The #2 Sensor Supply Circuit
P0645 A/C Clutch Relay Control Circuit
P0646 Low Voltage Detected At The A/C Clutch Relay
P0647 Voltage Detected At The A/C Clutch Relay
P0649 Cruise Control Lamp Control Circuit
P0652 Low Voltage At The #1 Sensor Supply Circuit
P0653 High Voltage At The #1 Sensor Supply Circuit
P0657 Actuator Supply Voltage A Circuit Open
P065a Generator System Performance
P0670 Glow Plug Module Control Circuit
P0671 Cylinder 1 Glow Plug Circuit
P0672 Cylinder 2 Glow Plug Circuit
P0673 Cylinder 3 Glow Plug Circuit
P0674 Cylinder 4 Glow Plug Circuit
P0675 Cylinder 5 Glow Plug Circuit
P0676 Cylinder 6 Glow Plug Circuit
P0677 Cylinder 7 Glow Plug Circuit
P0678 Cylinder 8 Glow Plug Circuit
P0683 Glow Plug Control Module to PCM Communication Circuit
P0698 Accelerator Pedal Position Sensor (APPS) Supply Voltage Too Low
P0699 Accelerator Pedal Position Sensor (APPS) Supply Voltage Too High
P06a4 Sensor Reference Voltage 4 Circuit Low
P06a5 Sensor Reference Voltage 4 Circuit High
P0700 Transmission Control System (MIL Request)
P0703 Brake Switch B Input Circuit
P0711 Trans Temp Sensor, No Temp Rise After Start
P0712 Trans Temp Sensor, Voltage Too Low
P0713 Trans Temp Sensor, Voltage Too High
P0720 Low Output Speed Sensor - RPM Above 15MPH
P0748 Pressure Solenoid Control/Trans Relay Circuits
P0830 Clutch Pedal Switch A Circuit
P0833 Clutch Pedal Switch B Circuit
P0850 P/N Switch Performance
P0868 Governor Pressure Sensor Volts Too High
P0869 Governor Pressure Sensor Volts Too Low
P0882 Trans 12 Volt Supply Relay Control Circuit Too Low
P0883 Trans 12 Volt Supply Relay Control Circuit Too High
P0973 Transmission Overdrive Circuit Voltage Too Low
P0974 Transmission Overdrive Circuit Voltage Too High
P1000 OBD Systems Readiness Test Not Complete
P1001 KOER Not Able To Complete, KOER Aborted
P1102 Mass Air Flow Sensor In Range But Lower Than Expected
P1148 Generator 2 Control Circuit
P1149 Generator 2 Control Circuit High
P115A Low Fuel Level - Forced Limited Power
P1184 Engine Oil Temperature Sensor Out Of Self-Test Range
P125a Power Enable Control Circuit Low
P125b power Enable Control Circuit High
P1272 A/C Clutch Control Circuit 2 Low
P1273 A/C Clutch Control Circuit 2 High
P1274 A/C Clutch Control Circuit 2 Open
P1275 A/C Clutch Control Circuit 2 Overcurrent
P1277 Starter Control Circuit 2 Low (tipm)
P1278 Starter Control Circuit 2 High (tipm)
P1279 Starter Control Circuit 2 Open (tipm)
P127a Starter Control Circuit 2 Overcurrent (tipm)
P127c Fuel Pump Control Circuit 2 Low (tipm)
P127d Fuel Pump Control Circuit 2 High (tipm)
P127e Fuel Pump Control Circuit 2 Open (tipm)
P0127 Fuel Pump Control Circuit 2 Overcurrent (tipm)
P1260 Theft Detected, Vehicle Immobilized
P1284 Aborted KOER — Injector Control Pressure Regulator
P1335 EGR Position Sensor Minimum Stop Performance
P1378 FICM Supply Voltage Circuit Low
P1379 FICM Supply Voltage Circuit High
P1397 System Voltage Out Of Self-Test Range
P1408 Exhaust Gas Recirculation Flow Out Of Self-Test Range
P1464 A/C Demand Out Of Self-Test Range
P1501 Vehicle Speed Sensor Out Of Self-Test Range
P1502 Invalid Test — Auxiliary Power Control Functioning
P1531 Invalid Test — Accelerator Pedal Movement
P1536 Parking Brake Switch Circuit
P1610 Interactive Reprogramming Code — Replace PCM module
P1611 Interactive Reprogramming Code — Diagnose Further
P1615 Interactive Reprogramming Code — Flash Erase Error
P1616 Interactive Reprogramming Code — Flash Erase Error, Low Voltage
P1617 Interactive Reprogramming Code — Block Programming Error
P1618 Interactive Reprogramming Code — Block Programming Error, Low Voltage
P1633 Keep Alive Power Voltage Too Low
P1635 Tire/Axle Out Of Acceptable Range
P1639 Vehicle ID Block Corrupted, Not Programmed
P1652 Short To Ground
P1703 Brake Switch Out Of Self-Test Range
P1705 Transmission Range Circuit Not Indicating Park/Neutral During Self-Test
P1725 Insufficient Engine Speed Increase During Self-Test
P1726 Insufficient Engine Speed Decrease During Self-Test
P1740 TCC Overdrive Solenoid Performance
P1756 Governor Pressure Not Equal To Target @ 35-40psi
P1757 Governor Pressure Above 3psi In Gear With 0MPH
P1762 Governor Pressure Sensor Offset Volts Too Low or High
P1779 Eng Torque Delivered to TCM Signal
P1780 Park/Neutral Pos [PNP] Switch Circ
P1781 Eng Torque Signal Circ
P1790 Trans Ctrl Mod Checksum
P1791 Trans Ctrl Mod Loop
P1792 Trans Ctrl Mod Reprogrammable Memory
P1792 ECM to TCM Eng Coolant Signal
P1793 Trans Ctrl Mod Stack Overrun
P1795 CAN Bus-Throttle Body Pos
P1800 TCM Power Relay Ctrl Circ
P1801 Perf Selector Switch Failure
P1804 Gnd Ctrl Relay
P1810 TFP Valve Pos Switch Circ
P1811 Maximum Adapt and Long Shift
P1812 Trans over Temp Condition
P1813 Torque Ctrl
P1814 Torq Conv Overstressed
P1815 Trans Range Switch-Start In Wrong Range
P1816 TFP Valve Pos Sw. -Park/Neutral with Drive Ratio
P1817 TFP Valve Pos Sw. -Reverse With Drive Ratio
P1818 TFP Valve Pos Sw. -Drive Without Drive Ratio
P1819 Internal Mode Switch-No Start\Wrong Range
P1820 Internal Mode Switch Circ A Low
P1822 Internal Mode Switch Circ B High
P1823 Internal Mode Switch Circ P Low
P1825 Internal Mode Switch-Invalid Range
P1826 Internal Mode Switch Circ C-High
P1831 PC Solenoid Power Circ-Low Volts
P1833 A/T Solenoids Power Circ-Low Volts
P1835 Kick-Down Switch Circ
P1836 Kick-Down Switch Failed Open
P1837 Kick-Down Switch Failed Short
P1842 1-2 Shift Solenoid Circ Low Volts
P1843 1-2 Shift Solenoid Circ High Volts
P1844 Torque Reduction Signal Circ Desired By TCM
P1845 2-3 Shift Solenoid Circ Low Volts
P1847 2-3 Shift Solenoid Circ High Volts
P1850 Brake Band Apply Solenoid Circ
P1851 Brake Band Apply Solenoid Perf
P1852 Brake Band Apply Solenoid Low Volts
P1853 Brake Band Apply Solenoid High Volts
P1860 TCC PWM Solenoid Circ Electrical
P1864 Torq Conv Clutch Circ
P1868 Trans Fluid Life
P1870 Trans Component Slipping
P1871 Undefined Gear Ratio
P1873 TCC Stator Temp Switch Circ Low
P1874 TCC Stator Temp Switch Circ High
P1875 4WD Low Switch Circ Electrical
P1884 TCC Enable/Shift Light Circ
P1886 Shift Timing Solenoid
P1887 TCC Release Switch Circ
P1890 ECM Data Input Circ
P1890 Throttle Pos Signal Input
P1891 Throttle Pos Sensor PWM Signal Low
P1892 Throttle Pos Sensor PWM Signal High
P1893 Eng Torque Signal Low Volts
P1894 Eng Torque Signal High Volts
P1895 TCM to ECM Torque Reduction Circ
P2000 NOx Trap Efficiency Below Threshold Bank1
P2001 NOx Trap Efficiency Below Threshold Bank2
P2002 Particulate Trap Efficiency Below Threshold Bank1
P2003 Particulate Trap Efficiency Below Threshold Bank2
P2004 Intake Manifold Runner Ctrl Stuck Open Bank1
P2005 Intake Manifold Runner Ctrl Stuck Open Bank2
P2006 Intake Manifold Runner Ctrl Stuck Closed Bank1
P2007 Intake Manifold Runner Ctrl Stuck Closed Bank2
P2008 Intake Manifold Runner Ctrl Circ/Open Bank1
P2009 Intake Manifold Runner Ctrl Circ Low Bank1
P2010 Intake Manifold Runner Ctrl Circ High Bank1
P2011 Intake Manifold Runner Ctrl Circ/Open Bank2
P2012 Intake Manifold Runner Ctrl Circ Low Bank2
P2013 Intake Manifold Runner Ctrl Circ High Bank2
P2014 Intake Manifold Runner Pos Sensor/Switch Circ Bank1
P2015 Intake Manifold Runner Pos Sensor/Switch Circ Range/Perf Bank1
P2016 Intake Manifold Runner Pos Sensor/Switch Circ Low Bank1
P2017 Intake Manifold Runner Pos Sensor/Switch Circ High Bank1
P2018 Intake Manifold Runner Pos Sensor/Switch Circ Interm Bank1
P2019 Intake Manifold Runner Pos Sensor/Switch Circ Bank2
P2020 Intake Manifold Runner Pos Sensor/Switch Circ Range/Perf Bank2
P2021 Intake Manifold Runner Pos Sensor/Switch Circ Low Bank2
P2022 Intake Manifold Runner Pos Sensor/Switch Circ High Bank2
P2023 Intake Manifold Runner Pos Sensor/Switch Circ Interm Bank2
P2024 EVAP Fuel Vapor Temp Sensor Circ
P2025 EVAP Fuel Vapor Temp Sensor Perf
P2026 EVAP Fuel Vapor Temp Sensor Circ Low Voltage
P2027 EVAP Fuel Vapor Temp Sensor Circ High Voltage
P2028 EVAP Fuel Vapor Temp Sensor Circ Interm
P2029 Fuel Fired Heater Disabled
P2030 Fuel Fired Heater Perf
P2031 Exhaust Gas Temp Sensor Circ Bank1 Sensor 2
P2032 Exhaust Gas Temp Sensor Circ Low Bank1 Sensor 2
P2033 Exhaust Gas Temp Sensor Circ High Bank1 Sensor 2
P2034 Exhaust Gas Temp Sensor Circ Bank2 Sensor 2
P2035 Exhaust Gas Temp Sensor Circ Low Bank2 Sensor 2
P2036 Exhaust Gas Temp Sensor Circ High Bank2 Sensor 2
P2037 Reductant Inj Air Press Sensor Circ
P2038 Reductant Inj Air Press Sensor Circ Range/Perf
P2039 Reductant Inj Air Press Sensor Circ Low Input
P2040 Reductant Inj Air Press Sensor Circ High Input
P2041 Reductant Inj Air Press Sensor Circ Interm
P2042 Reductant Temp Sensor Circ
P2043 Reductant Temp Sensor Circ Range/Perf
P2044 Reductant Temp Sensor Circ Low Input
P2045 Reductant Temp Sensor Circ High Input
P2046 Reductant Temp Sensor Circ Interm
P2047 Reductant Injector Circ/Open Bank1 Unit 1
P2048 Reductant Injector Circ Low Bank1 Unit 1
P2049 Reductant Injector Circ High Bank1 Unit 1
P2050 Reductant Injector Circ/Open Bank2 Unit 1
P2051 Reductant Injector Circ Low Bank2 Unit 1
P2052 Reductant Injector Circ High Bank2 Unit 1
P2053 Reductant Injector Circ/Open Bank1 Unit 2
P2054 Reductant Injector Circ Low Bank1 Unit 2
P2055 Reductant Injector Circ High Bank1 Unit 2
P2056 Reductant Injector Circ/Open Bank2 Unit 2
P2057 Reductant Injector Circ Low Bank2 Unit 2
P2058 Reductant Injector Circ High Bank2 Unit 2
P2059 Reductant Inj Air Pump Ctrl Circ/Open
P2060 Reductant Inj Air Pump Ctrl Circ Low
P2061 Reductant Inj Air Pump Ctrl Circ High
P2062 Reductant Supply Ctrl Circ/Open
P2063 Reductant Supply Ctrl Circ Low
P2064 Reductant Supply Ctrl Circ High
P2065 Fuel Level SensorB Circ
P2066 Fuel Level SensorB Perf
P2067 Fuel Level Sensor B Circuit Low Input
P2068 Fuel Level Sensor B Circuit High Input
P2104 Throttle Actuator Control System Forced Idle
P2121 APPS Conformance Error
P2122 Throttle/Pedal Position Sensor/Switch D Circuit Low Input
P2123 Throttle/Pedal Position Sensor/Switch D Circuit High Input
P2127 Throttle/Pedal Position Sensor/Switch E Circuit Low Input
P2128 Throttle/Pedal Position Sensor/Switch E Circuit High Input
P2132 Throttle/Pedal Position Sensor/Switch F Circuit Low Input
P2133 Throttle/Pedal Position Sensor/Switch F Circuit High Input
P2138 Throttle/Pedal Position Sensor/Switch D/E Voltage Correlation
P2139 Throttle/Pedal Position Sensor/Switch D/F Voltage Correlation
P2140 Throttle/Pedal Position Sensor/Switch E/F Voltage Correlation
P2146 Bank 1 (Cylinders 1-3) Shorted High Or Low
P2149 Bank 2 (Cylinders 4-6) Shorted High Or Low
P2199 Intake Air Temperature 1/2 Correlation
P2227 Barometeric Pressure Sensor Rationality
P2228 Barometric Pressure Circuit Low
P2229 Barometric Pressure Circuit High
P2262 Turbo/Super Charger Boost Pressure Not Detected — Mechanical
P2263 Turbo/Super Charger System Performance
P2266 Water In Fuel (WIF) Sensor Voltage Too Low
P2269 Water in Fuel Condition
P2284 Injector Control Pressure Sensor Circuit Range/Performance
P2285 Injector Control Pressure Sensor Circuit Low
P2286 Injector Control Pressure Sensor Circuit High
P2287 Injector Control Pressure Sensor Circuit Intermittent
P2288 Injector Control Pressure Too High
P2289 Injector Control Pressure Too High — Engine Off
P2290 Injector Control Pressure Too Low
P2291 Injector Control Pressure Too Low — Engine Cranking
P2299 Brake Pedal Position / Accelerator Pedal Position Incompatible
P242b Exhaust Gas Temp Sensor Circuit Performance - Bank 1 Sensor 3 -diesel
P242c Exhaust Gas Temperature Sensor Circuit Low- Bank 1 Sensor 3
P242d Exhaust Gas Temperature Sensor Circuit High - Bank 1 Sensor 3
P242f Diesel Particulate Filter Restriction - Ash Accumulation
P244a Diesel Particullate Filter Differential Pressure Too Low
P244d Exhaust Temperature Too High For Particulate Filter Regeneration Bank 1
P2453 Diesel Particulate Filter Pressure Sensor A Circuit Performance
P2454 Diesel Particulate Filter Pressure Sensor A Circuit Low
P2455 Diesel Particulate Filter Pressure Sensor A Circuit High
p2457 Exhaust Gas Recirculation Cooling System Performance
P245a Egr Cooler Bypass Control Circuit /open
P245c Egr Cooler Bypass Control Circuit Low
P245d Egr Cooler Bypass Control Circuit High
P2463 Diesel Particulate Filter - Soot Accumulation
P2503 Charging System Output Low
P2504 Charging System Output High
P2509 Ecm/pcm Power Input Signal Intermittent
P254c PTO Speed Selector Sensor Circuit Low
P254d PTO Speed Selector Sensor Circuit High
P2579 Turbocharger Speed Sensor Circuit Performance
P2580 Turbocharger Speed Sensor Circuit Low
P2609 Intake Air Heater System Performance
P268c Cylinder 1 Injector Data Incompatible
P268d Cylinder 2 Injector Data Incompatible
P268e Cylinder 3 Injector Data Incompatible
P268f Cylinder 4 Injector Data Incompatible
P2690 Cylinder 5 Injector Data Incompatible
P2691 Cylinder 6 Injector Data Incompatible
P2457 EGR Cooler Range/Performance
P2502 Charging System Error
P2509 Powerdown Data Lost Error
P2552 FICMM Circuit — Throttle/Fuel Inhibit Circuit
P2607 Low Voltage At The #2 Intake Air Heater Relay
P2608 High Voltage At The #2 Intake Air Heater Relay
P2609 No Voltage Drop Seen From Intake Air Heaters
P2614 Camshaft Position Output Circuit
P2617 Crankshaft Position Output Circuit
P2623 Injector Control Pressure Regulator Circuit
P2769 Transmission TCC Control Circuit Low
P2770 Transmission TCC Control Circuit High
P2a00 O2 Sensor 1/1 Circuit Performance
P2a01 O2 Sensor 1/2 Circuit Performance
U0001 Can C Bus
U0101 Lost Communication With Tcm
U010c Lost Communication With Turbocharger/supercharger Control Module
U0121 Lost Communication With Anti-lock Brake Module
U0141 Lost Communication With Fcm (tipm)
U1403 Implausible Fuel Level Signal Received
U1412 Implausible Vehicle Speed Signal Received
U1421 Implausible Ignition Key Off Time Received
U0100 Lost Communication With ECU/PCM A
U0101 Lost Communication With TCM
U0105 Lost Communication with FICM
U0155 Lost Communication with Instrument Cluster
U0306 Software Incompatibility with Fuel Injector Control Module
B1213 Less than two keys programmed to the system
B1342 ECU damaged (EEPROM in PCM not working, replace PCM)
B1600 PATS Ignition Key Transponder Signal Is Not Received
B1601 PATS Received Incorrect Key-Code From Ignition Key Transponder
B1602 PATS Received Invalid Format Of Key-Code From Ignition Key Transponder
B1681 PATS Transceiver Module Signal Is Not Received
B2103 Antenna Not Connected
B2431 Transponder Programming Failed
I purchased a reader for my kid at Costco for $37. 00. It reads and clears codes on his 95 and 01 Neon's, and worked on my 09 mini van, the wife's PT, and my 2010 PU. It's a little larger than a pack of smokes and he just throws it in the console.
