Engine/Transmission (1994 - 1998) Best setup
2nd Gen Non-Engine/Transmission how do i?.......
Getting close to the 100,000 mile mark. What is the best plate,injector, setup for towing, reliability, and fuel mileage? Going to do the KDP thing first and then a clutch. Already have gauges.
I call it useable hp
#10 plate with a 14 cm housing and a little tweaking won't win me any dyno runs but pulls any load I want smokeless at the speed limit. Free flowing airfilter, lose the cat, if your egts run high larger exhaust and flow though muffler. You'll think you're driving a different truck. You'll also gain 2-3 mpg while your new clutch lasts a long while. No need to keep your eye on the pyro constantly.
I like the setup illflem stated since you will already have a new clutch... I would consider throwing in a 3K GSK with that as well, just to give you that broadened power range:D
Bill, what is the #10 rated at for a '95 manual?
For all around performance don't forget the 370 injectors! They are worth another 45hp on top of whatever plate you decide on:D
I kinda wish I had put in 370's when I had the #8 Plate, I would like to see what it's like, bet you can control the EGT's better than mine.
Jim
For a 5 speed, the #11 plate does a great job. 285hp and 685 Ft-lbs. It is borderline with the stock clutch. I tow 20,000 to 25,000 gross routinely and it works great. It will pull posted grades at over 50mph with these loads, and at 1750 - 2000 rpm in top gear no overdrive. More speed up the grades is possible if you bring up the rpm, but, on a long posted grade, the temp will continue climbing until you get out of it. Also, with the #11 plate and staying below 2100 rpm, it will not overheat, the EGT will stay reasonable and safe. So, constant monitoring of the gage is not needed. It is a good plate for sustained output without having to worry about EGT or overheating. Still, a very strong up grade from stock. Feels like a muscle car!!
I thought the #10 plate on the 5 speed was bigger than the #11. Can some one verify that? Or is the 94 different than my 96??
Doug Rees
The 96 is 215 hp and the earlier ones are 160hp with variations for auto trans (less power) and different years. The #10 plate in a 96 or newer 12 valve is a BIG power increase, the #11 is 285 hp and the 10 is more than that. Dont know for sure on the earlier 2nd gens what years are what HP.
Yes, the #10 is bigger than the #11, but the actual power figures vary by pump year like Deezul said. That is why I asked what the #10 was rated at for the '95 5spd, because I know it is rated at 330/750 for a '96-98 5spd, but the '95 had a different pump. So now we know that the #10 for a '95 5spd is rated 220/570 (which is obviously well short of the '96-'98 version).
I too, have been confused about the actual power figures of the hotter plates in older pump models...
Wes
I just wanted to clarify the 94-94 5 speeds are 175hp, the 94-95 autos are 160 hp.
The 96-98. 5 5 speeds are 215hp and the 96-98. 5 autos are 180 hp.
A #10 in a pre 96 5 speed is not that big of a plate (220hp). A #10 in a 96-98. 5 5 speed is a pretty hot plate (330hp).
Thanks guys
Thanks guys, I will let you all know what and when I do it. It does look like it will all happen in the next year, with present mileage and use.
How are the South Bend clutchs holding up? Anybody know?
My Southbend is rated at 350HP and is holding quite nicely at 417HP and I know of one TDR member that has the same clutch and it finally started slipping at 485hp so they are very good clutches.
