* * * ENDING DATE ADJUSTED TO May 31 due to TDR Staff Member Error. Thread was accidentally locked to posts from May 9 - 11, 2012 due to a clerical error. So contest date is being extended through May 25, 2012. I apologize for our error.
CFM+ is a high-tech engineering company with a patented manufacturing process that allows them to produce one-piece hollow structures from high-temperature structural composite materials. Similar composite materials are used to make engine parts for a number of race applications as well as for high-end stock automobiles like the Corvette LS Series and in turbo charged vehicles. Composite materials are used in these applications due to their insulative properties which allows them to avoid the heat sink that occurs with similar parts cast from aluminum. All CFM+ Intake Manifolds are manufactured in the United States.
We'd like to thank CFM+ for sponsoring our latest giveaway - a CFM+ Intake Manifold. What do you have to do to win? This one is easy and fun. Simply post the stupidest warning label you've seen recently.
Extra points will be awarded to those of you creative enough to find a stupid warning label involving fuel, diesel fuel, trucks or anything automotive.
Good luck, and most of all, have fun!
Correction: Since the contest was extended due to website issues, the final entries will be made on Friday, May 25. Winner will be selected by CFM+ and posted just as quickly as possible after the contest closes.
Need some ideas? Here are two:
