After going through about 14 thermostats within 2 years I gave up. All but one thermostat stuck shut and the engine overheated except one that stuck open while off road near Estes Park, Colorado and I could barely keep the engine temperature above freezing while driving down the mountain. This engine ran hot for years until I finally discovered this summer that I had the tiniest air leak in a coolant hose letting air get into my system which propagated frequent overheating, but not enough of a leak to let coolant escape anywhere but through the radiator cap.
I'm now in Missouri and to my surprise with all of my highway driving and temps only down into the 30s thus far, my coolant is rarely as warm as 140 degrees F. In the past few weeks I've noticed a change in my exhaust smoke. When cold at an idle I have light gray, almost white smoke coming from the tailpipe. Even after driving for an hour when it's cool out during acceleration when the smoke used to be black, it is now very light gray, just a thin haze, almost white.
When the ambient temperature is over 60 degrees I see no haze at idle and exhaust smoke is darker, almost black. Engine coolant is also warmer then, usually above 140 degrees. I am frequently seeing coolant at highway speed reading around 120 degrees when the weather is cooler. When I last checked my engine oil I noticed the slightest blueish tint which I think is diesel. I'm assuming that because my engine is not getting warm enough I'm getting an incomplete fuel burn and diesel is washing past the pistons. Isn't this correct that a cold diesel smokes white because it is not warm enough to completely ignite the fuel? Does this sound like a likely scenario?
Power is still fine and boost quickly reaches the mid 40s but with a very lightly colored smoke. When the weather was warmer I saw 15 mpg and am now down to 13. I am also wondering if it could just be that I dialed back the star wheel quite a bit. I have the AFC and plate full forward but the anneroid dialed way back to decrease smoke. Is part of the reason the smoke is so light that I have it dialed back?
I have a massive 32 lb alternator making the thermostat very difficult to change. I siliconed the large o-ring to a thermostat I gutted. I am contemplating the possibility of somehow installing a thermostat in the upper radiator hose so that replacement is easier if I continue to have problems with new thermostats. Does anyone have any ideas on how to go about this idea? I tried Cummins, Dodge, NAPA, Auto Zone, Advance Auto, Car Quest, and other off the shelf thermostats with no luck. I've also pondered designing a manual thermostat but it would worry me if someone else unknowingly left it shut and overheated.
I read a post of someone being very pleased with a Mr. Gasket 180 degree thermostat. I have noticed there are quite a few aftermarket brands and I'm wondering if anyone has experience or an opinion on what brand should be most reliable. Preferably a model without the big rubber sleeve that gets caught up and jammed. I figure 180 is what Cummins intended but am interested in temperature suggestions and reasons why as well. I remember reading articles about fuel economy competitions in which higher coolant temperatures even around 300 degrees aided mileage but I hear most dodge people say the Cummins performs better the cooler it can run. Thoughts?
Thanks,
Matt
Thanks,
Matt
