Other than Michelins, whisj brand seems to be the best tire?
My truck came with Goodyear but 2 sets didn't last long. I now have Firestones on the rear and Cooper the front.
As part of the learning experience i found out that I was inflating my tires wrong, the wore more on the center-over inflatiion. The door sticker sayw 55 psi for the rear duallys. Way to much for my load. I ran the scales with my trailer hooked up and found out that 40 psi each was the MAX. Now I'm running 35, slightly less than needed and way less than the 80 psi one tire dealer told me to run "because that is what it says on the tire"
Right now they are running 3/32" depth in the center and 6-7/32 on the outside.
What is the minimum depth that I should let the center go to before replacing them?
when you are close to the wear bars... . junk them
What get you is the high shipping charges.
Sam's Club does, also Wal Mart (related). If you can't find either of these, you need to move...
