I've got a Goerends converter/transmission. I've said it before and I'll say it again... . With the ammount of torque that our trucks are putting down you have to do one of 3 things.
1: Band-aid it. Throw unnessissary billit shafts into the trannys so you can make the truck shift way to firm.
2: Build a converter that is tight on the bottom end but loostens up on the top end so when it shifts, it has a cushion.
3: Spend some time, design a valvebody/shift kit that will shift smoothly, but firmly. Set it up so it's not Shocking the shafts in the transmission and build a converter that Starts out TIGHT and gets Tighter.
When you shock the shafts in the transmission and I think of it like a long extension on a stuck bolt. If you ease into that extension you can put more torque on that bolt and extension before something breaks. If you just SLAM your way into it, it will break.
I have pulled a few times with my Goerends transmission and Daves' patented tight-tighter triple disc converter. I left it in D, locked out OD and let the transmission do the work. I NEVER felt it upshift or downshift. Last fall I was at around 350hp. During that last pull it was a VERY hard track surface with fair Yokohama Geolander A/T tires. I got down to the end of the track where the sled stopped me, it downshifted from 3rd to 2nd to 1st and proceeded to spin and smoke all 6.
I've drag raced this truck with the same converter. I have a lock-up switch that actuates at 35mph. I've ran it both ways. It didn't matter.
On the road when it grabs lock-up it only drops about 75rpm.
I think it's all the advantages of an Automatic, with as close as possible lock up as a clutch.
Josh
PS, Lifetime warranty on the converter and 100,000miles on the transmission, I'm sold.
