re-visiting thread
Do you prevent the truck from ever starting? (clutch switch, starter wire, cam/crank wire)
Or
Do you allow the truck to start, roll a mile and die? (lift pump)
If you can't start the truck, your going to pull the radio, look for switches, break stuff. then run away.
If you can drive, they'll leave quicker, but it will stall, what would one do if they have a broken truck after 1 mile? Would one run? or proceed to look for a switch? attempt to at least hit a tree?
The general public here tends to lean toward not starting at all. But I know I can split wires into my intake lift pump and look factory at that.
Now a slightly more personal question of you all. . Where do you put your switches. . I have one idea thus far. And it would be the last place I personally would look for one.
Under seat? first place. dash? second place I'd look.
Anyone ever use a magnet activated switch? That sounds like a real trip idea
