Best way to set up a fuel pressure guage?
what other turbo's will fit
Bellhousing Adapter
OK, so my 93 has 170K, my 92 has 300K, I'm curious about my lift pump(s) health. Is there any convenient spot to add a t or an 1/8 npt port along the line that goes from the lift pump to the injector pump, or is there already one somewhere? What pressure should I be looking for at idle/WOT in fifth gear? Any recommendations on guage brand? Thanks-Nick
You can buy a tapped banjo bolt from Geno's. I have an electrical gauge set up- keeps fluids out of the cab. I see 7-8spi at idle, I can suck it down to 0 at WOT, making 30-31psi boost in 4th and 5th (Airtex stock style LP). Minimum spec is 3psi at WOT, I think. I'd prefer to keep it above 5psi, though, just to be safe.
Daniel
When you need gauges, contact member blacksheep4x4, he can get several brands, isolaters, etc. He'll give you a good deal, and service! ;)
