Maybe I am overlooking a few things, but here is what I found out about the Open Range and some of the issues brought to light so far...
Quickly scanning the website I see six lug 16" wheels, top of the line fifth wheels have eight lug wheels to carry the weight.
I notice on the spec page they list tires as 16". What size are they and whey don't they list the size?
I have attached a picture of the 8 lug 16" wheels... can't see the tire size but can see that they are an ST.
I could have missed it but I saw no mention of contruction methods, insulation, or R values. Aluminum framing is light in weight and won't rot in the case of a water leak but when trailer frames flex, as all of them do, aluminum joints and welds crack. Aluminum is typically used in side walls but I've never seen it used in floors. A glance suggested aluminum framing in walls, floors, end caps, and roof.
The website states "Four-Season Protection Package standard - up to R-39* Roof, R-38* Floor, R-9 Sidewalls - Included". I see they say "Up To" so I am sure that is not the R values for those entire areas. Double Pane windows are an option I would spec so maybe the trailer will have a decent overall insulation package for the price.
Here are a few other items concerning their construction that I noted and wouldn't mind some input on:
* 5-Sided welded aluminum superstructure (walls and floor) as HB noted
* 2" laminated high gloss automotive metallic finished exterior wall
* 5" roof truss rafters
* Enclosed underbelly
* Heated and enclosed holding tanks and dump values
* In-floor heated and enclosed insulated water lines
* Double insulated 1" thick radius baggage doors with continuous one-piece hinge and interior fasteners
* Oversized clean and clear heated exterior pass-thru storage
* Custom Dexter Wide Stance E-Z Lube™ axles and EZ Flex™ suspension
* SymaLITE™ interior wallboard
* Maple hardwood raised-panel glazed cabinet doors with hidden hinges and a 10-year warranty
* Winterizing siphon hose
* Under-mount spare tire and carrier
* High Performance Furnace
* Vented attic
* Insulated bedroom floor
* FlexFoil™ insulation in floor and ceiling
* 97% temperature reflective foil in slide floors
* Heated exterior-access Convenience Center for utilities
* Digital thermostat
